[25-03-2014] 433 MHz KAKU
A project log for Raspberry Home Automation Cluster
A high availability Raspberry pi cluster for home automation purposes. Simple, low on energy, but very stable.
Michiel SpithovenMichiel Spithoven 03/25/2014 at 08:380 Comments
I came across a special offer on KAKU outlets from some Dutch home depot, so I bought some and added a set of 433 MHz ASK modules to the cluster.
After doing the research on internet I found the following code for controlling the KAKU wireless outlets: http://weejewel.tweakblogs.net/blog/8665/lampen-schakelen-met-een-raspberry-pi.html
I works like a charm!
