[04-04-2014] Still going strong!
A project log for Raspberry Home Automation Cluster
A high availability Raspberry pi cluster for home automation purposes. Simple, low on energy, but very stable.
michiel-spithovenMichiel Spithoven 04/04/2014 at 07:280 Comments
This morning I checked the cluster for errors, but there were none. No errors, no change in slave/master roles or whatsoever. : )
Furthermore the 433 MHz ASK modules still work like a charm! The light sockets seem to respond better to the Raspberry cluster, then to the original remote.
Other little update>> The TV, digital TV tuner, radio etc. are switched off at night, and are powered back on in the morning. This will save some extra €15,- on standby-power a year.
