Scaling issues
08/17/2015 at 15:18 • 0 commentsThe models look good, but their scale isn't quite right for Cynthia, so she will be shrinking the staff design some.
Staff Features
08/17/2015 at 12:12 • 0 commentsWe plan on implementing sound and lighting effects of Lux's Q,W,E, and R abilities. Lux's sound files can be found here.
Prepping The Pieces For Paint
08/17/2015 at 09:21 • 0 commentsFirst, the pieces need to be smoothed out. The two best methods would be to either expose the pieces to acetone vapor or to coat it in "XTC-3D." Next, applying bondo to fill in imperfections. Once dry, the pieces are to be sanded smooth and even. Then, spray painted a base coat for paint to adhere onto. Lastly, several coats of colorful paint and a matte or glossy lacquer as a finish.
Design of electronics
08/17/2015 at 08:27 • 0 commentsWe planned to build a small ledge inside the shaft of the wand to place the controls. It will implement a capacitive touch based 4 button system to cast the 4 major spells of Lux.
Chris Hamilton
