Buy
http://www.seeedstudio.com/depot/Grove-Moisture-Sensor-p-955.html
Wiki
http://www.seeedstudio.com/wiki/Grove_-_Moisture_Sensor
Hardware
| Vcc | 3.3 V |
| Gnd | Gnd |
| Sig | Trinket A1 (Analog 1) |
Arduino code
#define PIN_MOISTURE A1
void setup(void) {
pinMode(PIN_MOISTURE, INPUT);
void loop(void) {
int moistureVal = analogRead(PIN_MOISTURE);
