[Trinket sensing] Push-buttons (using interrupts)
A project log for Home automation - Trinket Sensing
tjTJ 06/08/2015 at 10:270 Comments
Hardware
PB1_SIGTrinket Pin 11
PB2_SIGTrinket Pin 12
Learn about arduino interrupts
http://playground.arduino.cc/Main/PinChangeInterrupt
Arduino Code
#define BUT_RIGHT 11
#define BUT_LEFT  12
void pciSetup(byte pin)
    *digitalPinToPCMSK(pin) |= bit (digitalPinToPCMSKbit(pin));  // enable pin
    PCIFR  |= bit (digitalPinToPCICRbit(pin)); // clear any outstanding interrupt
    PCICR  |= bit (digitalPinToPCICRbit(pin)); // enable interrupt for the group
ISR (PCINT0_vect) // handle pin change interrupt for D8 to D13 here
 /* if (digitalRead(BUT_RIGHT) == LOW || digitalRead(BUT_LEFT) == LOW)
    display.refresh();*/
void setup(void) {
  pinMode(BUT_RIGHT, INPUT);
  pinMode(BUT_LEFT, INPUT);
  digitalWrite(BUT_RIGHT,HIGH); // set pullup - not required - hardware pullup
  digitalWrite(BUT_LEFT,HIGH); // set pullup - not required - hardware pullup
  pciSetup(BUT_RIGHT);
  pciSetup(BUT_LEFT);
