moving robot
A project log for LinoRobot : Robot Operating System
Linobot is an autonomous robot that moves around a floor space. Its build on top of the robot operating system.
kelster101757kelster101757 04/30/2018 at 19:550 Comments
We finally got the robot to move.   See the video here
Problems Solved
Teensy Bootloader > We could not get the pi to connect to the teensy. Discovered we had got the teensy and a nano mixed up at some point *face palm*, now works as expected
Power issue > The power unit was failing to charge, however after checking the powers supply plug we were using we discovered that it was outputting just under 5V volts instead of its rated 12V. Replaced power supply and now working fine.
Solid Core Motor wires > Kept breaking so changed to stranded.
A stable virtual box for the development computer > Bob has setup a stable Linux box with the ROS image for the development computer working on the virtual box.
Robot Pi > setup with all the packages installed.
Next challenges
setup the Microsoft Kinect for the robots eyes > Matt ordered one from ebay so we can start implementing it. Will be interesting as the github guide does not cover its setup.
Static IP address for Wifi on Robot Pi >The current static IP address is only for the ethernet connection, need to get this changed so we don't have trailing wires.
Encoders > We now have two encoders but they don't fit the base mount so going to have to glue them on instead. Once in we can configure the Odometry settings.
Mounting & powering the Pi > The Pi need mounting on the robot and will need powering from the power unit >>> assuming the 5V stepdown already on the unit is for this?
Cleaning up the wiring > we need a breakout board to mount the teensy, IMU and the connecting wires to the power, drivers & encoders. Current setup is a bit of a nightmare
Motor delay when turning > there is currently a delay when sending the turn command to the robot, there is a short whine for about a second before the motor begins to turn. not sure if this is an issue with how we have the drivers wired up?
