Single WS2812 OpenHab Bridge
A project log for ESPLamp
A Web (OpenHAB) enabled RGB-LED Desktop Lamp
xiiderXiider 06/11/2015 at 20:160 Comments
So, I added a Lua Files, which allows you to control a single WS2812 Led from the openHab Server. This might be useful if you have a ESP-01 Model, and a WS2811 Driver IC laying around and want to use your analog RGB Strip as an IoT Device.
Demo and Schematics will follow, but it is quiet simple, you should figure it out.
