Single WS2812 OpenHab Bridge
06/11/2015 at 20:16 • 0 commentsSo, I added a Lua Files, which allows you to control a single WS2812 Led from the openHab Server. This might be useful if you have a ESP-01 Model, and a WS2811 Driver IC laying around and want to use your analog RGB Strip as an IoT Device.
Demo and Schematics will follow, but it is quiet simple, you should figure it out.
Initial Log
06/08/2015 at 20:22 • 0 commentsQuick initial Log:
The OpenHAB Binding should already work, also updating in both ways, also the updating of the RGB Chooser in the various OpenHab interfaces works.
The ESP can already receive commands, but due to the lag of multipin ESPs I can only test it with one or two leds.. ESP-12 have already left the airport in china, now I only have to pray to the custom god of germany..
Xiider
