PiClock - A Raspberry Pi Clock & Weather Display
This project is a fancy Clock and weather display built around a monitor and a Raspberry Pi.
The PiClock is a clock (duh), weather forcast, and radar map display based on the Raspberry Pi and a display monitor. The display monitor is assumed to be an HDMI monitor, but it will probably (possibly) work with the composite output as well, but this is not a design goal. The main program (Clock/PyQtPiClock.py) will also run on Windows, Mac, and Linux, as long as python 2.7+ and PyQt4 is installed.
The Weather data comes from Weather Underground using their API (http://www.wunderground.com/weather/api/ ). The maps are from Google Maps API. You must get an API Key from weather underground in order to make this work. It is free for low usage such as this application.
The PiClock can be customized with several supported additional things:
RGB LED strips (NeoPixel) to create an ambilight effect
gpio buttons for changing the view
IR Remote Control for changing the view
Streaming the NOAA weather radio strea
Introduction
The PiClock is a clock (duh), weather forcast, and radar map display based on the Raspberry Pi and a display monitor. The display monitor is assumed to be an HDMI monitor, but it will probably (possibly) work with the composite output as well, but this is not a design goal. The main program (Clock/http://PyQtPiClock.py) will also run on Windows, Mac, and Linux, as long as python 2.7+ and PyQt4 is installed.
The Weather data comes from Weather Underground using their API ( http://www.wunderground.com/weather/api/ ). The maps are from Google Maps API. You must get an API Key from weather underground in order to make this work. It is free for low usage such as this application.
  • RGB LED strips (NeoPixel) to create an ambilight effect
  • gpio buttons for changing the view
  • IR Remote Control for changing the view
  • Streaming the NOAA weather radio stream for your area
The power usage I've measured is about 35watts with a 19" HDMI Monitor, 27 LEDs and the Pi. The LEDs contributed 3 or so watts, and I think the Pi is about 2-3 Watts normally.
This is the basic PiClock, with some options added. PiClock Picture
I chose to remove the plastic frame from my monitor and mount the Pi directly on it, as well as tap power from the display's power supply. PiClock Pi Mounting
I've made it work on multiple platforms and form factors. PiClock Pi Mounting
And I've made some for friends and family with different customizations. PiClock Pi Mounting
Overview on GitHub
There's an overview, install guide and hardware guide along with the source on GitHub. https://github.com/n0bel/PiClock/blob/master/Documentation/Overview.md
There is also an instruction guide here on Hackaday.io. https://hackaday.io/project/6184-piclock-a-raspberry-pi-clock-weather-display#menu-instructions
PiClocks have been successfully built and proudly displayed around the world by many people. Some examples can be seen on closed github issues, as well as my public facebook page. I can't tell how many PiClocks are out there. The github page shows 47 forks and 242 stars. Here on Hackaday.io, there are almost 100 skulls (likes) 40,000 views and over 1,000 followers. As well as 90 comments in the form of questions and answers.
I try to answer questions either here or on github, or facebook or reddit.
I've made several PiClocks for friends and family. A few friends have made their own as well.
Maybe you'd like to give it a try.
Here are some successful PiClock build pictures.
Craig Moench
blboyd
Micheal Jacques
  • 1 × A Raspberry Pi (revision 2) Model B, or B+ or Pi 2 Model B or Pi 3 or Pi Zero
  • 1 × A Display Monitor & Cable
  • 1 × 5V Power Supply (for Pi) Power Supply (or if you're ambitious tap your display power supply, you'll probably need a switching down regulator to 5v) Remember the Pi likes something that can source up to 2A.
  • 1 × A USB Keyboard and Mouse for setup (if you want something small and semi-permanent, I've had good luck with this: https://www.google.com/search?q=iPazzPort+2.4G+Mini+Wireless+Keyboard I like the one with the mousepad on the side)
  • 1 × USB Wifi or Internet Connection
View all 10 components
View all 19 project logs
  • 1
    Step 1
    Choosing your Options
    The PiClock in its basic configuration is a Raspberry Pi, and an HDMI Monitor (and power and SD card of course, and possibly a WiFI dongle). This project has a number of optional items.
    • NeoPixel Ambilight
    • DS18B20 Temperature sensors
    • IR Receiver
    • Push Button controls
    You could proceed through these instructions without any of these hardware extras, and then add them later.
    All of the optional hardware wiring and instructions are documented here: https://github.com/n0bel/PiClock/blob/master/Documentation/Hardware.md
    I'd suggest you read through that first if you're considering adding these options.
  • 2
    Step 2
    Hook things up
    Begin by setting up your HDMI Monitor, Raspberry Pi, and power supply. Some kind of keyboard and mouse will also be handy, connected via USB. I'm assuming most everyone can get this far on their own. If you're going to do those hardware extras, mentioned in the prior instruction, put them together as well.
  • 3
    Step 3
    Download Raspbian Jessie and put it on an SD Card
    PiClock and this install guide are based on Raspian Jessie released on https://www.raspberrypi.org/downloads/ It will work with many raspbian versions, but you may have to add more packages, etc. That exercise is left for the reader.
    What follows is a step by step guide. If you start with a new clean raspbian image, it should just work. I'm assuming that you already know how to hook up your Raspi, monitor, and keyboard/mouse. If not, please do a web search regarding setting up the basic hardware for your Raspi.
    The image and instructions for doing this are on the following page: https://www.raspberrypi.org/downloads/
View all 22 instructions
raflynasution123 wrote 7 days ago point
zzz
wilhelmvibritannia wrote 05/03/2018 at 07:28 point
Hi! I've been testing this app for a few days for my school project, and it's really really nice. Do you think it's possible to add a news feed or some kinda new widget in PiClock? For example replacing a few squares of predictions to add something there.
Thank you so much!
philip2016winther wrote 03/23/2018 at 16:30 point
Can you make it so i can choose language for Weather underground API. Because its showing in english, and i know that they support my language (Danish/DK) besides that it is a great project. the api link looks like this:
http://api.wunderground.com/api/xxxxxx/forecast/lang:FR/q/France/Paris.json
xxxxxx = my api key
john.h.krantz wrote 03/10/2018 at 22:47 point
This is a great app.  I have just started using in and really enjoy it.  I was wondering if you have any intention to make the screen touch sensitive.  I am using it on the raspberry Pi 7" touch screen and would like to mount it on the wall and do away with the keyboard. Thanks for all your work.
cfrashie wrote 02/24/2018 at 21:15 point
I am curious is there a way to import traffic on the google maps?
Rick wrote 01/13/2018 at 02:25 point
Anyone having issues with Maps showing up? The Radar works, but google maps no longer showing. Just started doing it. Not sure where to start.
Wayne Westfield wrote 01/21/2018 at 00:30 point
Hi, I just got done today and what I am seeing is a Gray background with specks here and there on a loop but no map details with WU int he right hand lower corner.  I also tried the example configs and they do the same thing.
Wayne Westfield wrote 01/22/2018 at 01:01 point
Hi Rick,
I just found that if I remove the google API key from the APIKeys.py that everything works now.
Good luck.
kirtiabhay wrote 12/31/2017 at 23:10 point
Hi Kevin, This is really great project with time, weather and radar precision...thanks for detailed instruction and I made it work exactly what shown here. It is working also at boot up but just have a question if you could guide me how to run this PiClock at given interval. I have some other slideshows which I would like to run on-screen with PiClock at certain interval concurrently running by switching from piclock to slideshow and vice-versa. I am trying to make an interactive display with time interval showing both slideshow and PiClock. Thanks a lot and appreciate your help.
pmk2510968 wrote 12/20/2017 at 20:05 point
I have the import error: no module named apikeys when I tried to run it, any help please?
duncan.galloway wrote 12/08/2017 at 08:54 point
Hi Kevin, great project, worked very well for me! I want to show the conditions and time for a different location (and different time zone). The location is easy to configure with the relevant location in Config.py, but I don't want to have to set my system clock for the different zone to display the time there. How do I show the time in another zone?
bethwalker15 wrote 12/06/2017 at 02:32 point
Over the last 3 days our Piclock has suddenly started exceeding the number of allowed calls for my WU API key.  We've regenerated the key and the problem still exists. Any suggestions?
paul wrote 12/05/2017 at 20:23 point
Just a simple question, does this display show weather alerts for the area?
spenser_snyder wrote 11/20/2017 at 03:52 point
How does one get rid of the Analog Clock in order to Show the time in Digit Form?
wypfl9 wrote 11/09/2017 at 16:03 point
Love it .. is it possible too show additional time zones on the left and or a newsfeed?
gdm44752 wrote 09/30/2017 at 20:18 point
Thanks buddy! It's a nice and simple idea and construction. I just made one for my self, we have it in the living room connected to the TV, anytime we want to check the weather we just switch to the HDMI port and voila! :) just in case I made a video-journey during my experience in this project
ryanuptain wrote 09/25/2017 at 01:23 point
Hello Kevin (and all you guys who know what you are doing),
So I set this amazing little guy up. I just have a couple questions...so far...
How can I change the background and the style of the clock? I don't want to mess around and ruin the code...I am a beginner. Thanks!
gdm44752 wrote 09/30/2017 at 20:20 point
It's easy, take a look here, by the end there's how to change and load the different backgrounds, icons styles.. etc.
You can do it via SSH or/and FileZilla
jratha wrote 09/23/2017 at 12:03 point
Hi Kevin.
Just a quick Query/ Is it possible to show the the attached temperature sensors in °F instead of just numbers. Like in the top left of my screen?
Wilson wrote 08/15/2017 at 14:09 point
Would it be possible to pull the Google Maps traffic API and show that also? Looking for any knowledgeable to help..
Thanks
Danny Martin wrote 07/20/2017 at 15:48 point
Kevin I am still having trouble with the NeoPixel lights. I have tried 4 different brands of lights including a Adafruit NeoPixel Ring with the same results. I have even tried running just the NeoAmbi.py stand alone. I would welcome any additional help you might have.
Thanks
Danny Martin wrote 06/28/2017 at 19:28 point
Hello Kevin:
I am trying to get the LED strip to work with the PIClock. I have tested my strip and all is well with that. I have installed the following:
apt-get install libboost-python1.49.0
I have searched all the discussions and don't seem to find any references to the LEDs, I did some research on NeoPixel Ambilight, but not sure this is what I want to do. Do you have some code or option to select that turns on the lights, or  should I just set up a python script to start  at boot and use that? Any  help would be appreciated, again thanks for the wonderful project.
Danny
Kevin Uhlir wrote 06/28/2017 at 21:51 point
The LEDs are run by the script and library in the Leds folder.   It is started along with everything else in startup.sh
Danny Martin wrote 06/29/2017 at 03:34 point
I am using the Raspberry Pi 7 inch display. Does this code look for an HDMI monitor? I cannot get the leds to come on. Do I need to select a special GPIO (currently using 18)?
Kevin Uhlir wrote 06/29/2017 at 03:52 point
PiClock doesn't care about your monitor.  It uses whatever desktop gui is running on.
https://github.com/n0bel/PiClock/blob/master/startup.sh runs NeoAmbi.py from the Leds folder (around line 75).
https://github.com/n0bel/PiClock/blob/master/Documentation/Hardware.md shows how to hook up the NeoPixels.
Danny Martin wrote 06/30/2017 at 03:48 point
Kevin I have my neo pixel installed properly, I can make it function by using the script strandtest.py with my current connections. I have tried both the NeoPixel Ring - 24 x 5050 RGB LED with Integrated Drivers and Adafruit NeoPixel Digital RGB LED Strip - White 30 LED - WHITE. Both with the same results. Any more suggestions?
Thanks,
Danny
Kevin Uhlir wrote 06/30/2017 at 04:42 point
no idea... have you tried manually running
cd Leds
sudo python NeoAmbi.py
If so does it get any errors?
Danny Martin wrote 06/30/2017 at 05:41 point
I have tried that and it just seems to run with no activity. When I hit Ctrl C it just aborts the program. Is there any changes that need to be made in the NeoAmbi.py in reference to the number of pixels that are being used?
Thanks,
Danny
Kevin Uhlir wrote 06/30/2017 at 05:45 point
in NeoAmbi.py line 32
Danny Martin wrote 06/30/2017 at 15:58 point
Kevin, I would like to run a test of Ambi.py on a standalone pi. Do I need to load any additional software or all of the libraries contained in Raspbian Jessie?
Thanks,
Danny
Danny Martin wrote 07/02/2017 at 21:37 point
Kevin I ran the test  with a clean install of Raspbian and  ran your Ambi.py with no results. What is the type and brand name of the strips you used in your project?
Thanks
Kevin Uhlir wrote 06/24/2017 at 17:55 point
NOAA weather radio streams have reappeared on the net. You can find it here: http://noaaweatherradio.org/
They don't put the .mp3 urls where they are easily accessable, so you
need to use your browser to "View Page Source" in order to find the
proper .mp3 url.
