Raspbian Wheezy is no longer on the download page, here's where to find it.
A project log for PiClock - A Raspberry Pi Clock & Weather Display
This project is a fancy Clock and weather display built around a monitor and a Raspberry Pi.
kevin-uhlirKevin Uhlir 07/09/2016 at 16:130 Comments
Raspbian Wheezy is no longer on the download page. https://www.raspberrypi.org/downloads/ Jessie is rolled into the latest download for Raspbian. and Wheezy has been removed from the download page. Some hardware functions (temperature, buttons, ir) won't work if you use Wheezy. (Yes, I need to get to updating some of the PiClock software to get this to work). The last version of Wheezy is archived here: https://downloads.raspberrypi.org/raspbian/images/raspbian-2015-05-07/2015-05-05-raspbian-wheezy.zip
This probably won't work on a PI 3. For that, see here: https://www.raspberrypi.org/forums/viewtopic.php?f=91&t=138149
