#‎RaspberryPi‬ ‪#‎PiClock‬ gets some new features.
A project log for PiClock - A Raspberry Pi Clock & Weather Display
This project is a fancy Clock and weather display built around a monitor and a Raspberry Pi.
kevin-uhlirKevin Uhlir 07/23/2016 at 23:260 Comments
Language support
The config file now contains a wuLanguge setting (set according to the API's language codes), which will change the language of the forecast and current conditions. In additon, DateLocale has been added to specify the locale for showing the date. The locale must be installed in the Pi before it works. Also new in the config for supporting languages are several variables that can be changed to reflect a language specific word. Previously words like 'Pressure' 'Humidity', etc were hard coded. Now they can be tailored for the proper language.
Satellite Images
Some areas of the world aren't covered by Weather Underground's radar api. I'm assuming it has to do with access to weather radar data that must be obtained from various European services. In those cases the Satellite IR images are available. I've included a new config variable 'satellite' set to 0 or 1. Set it to 1 to use satellite images instead of radar images. The satellite images are IR images showing the temperatures (height) of the cloud tops or ground.
Dimmable Radar Images
When I made the bedside version of the PiClock, it was way too bright. Turning down the LCD made the other parts of the clock less readable, so I added the ability to overlay the radar image with a dimming mask. You can set the color, and the alpha (transparency) in the config.
