#PiClock gets a Digital Clock mode
A project log for PiClock - A Raspberry Pi Clock & Weather Display
This project is a fancy Clock and weather display built around a monitor and a Raspberry Pi.
kevin-uhlirKevin Uhlir 09/10/2016 at 20:130 Comments
One of the most requested features of the #PiClock has been a Digital option rather than the analog clock that is the default.. So here you go! Config-Example.py has 2 examples of a digital clock format for the pi. I've also updated the instructions a bit, cleaned up startup.sh to be more friendly about useless errors, and added another (faster) option for autostarting the PiClock on your Pi. Ready Set Go! https://github.com/n0bel/PiClock http://n0bel.net/v1/index.php/projects/raspberry-pi-clock/46-piclock-goes-digital
