DHT22 Temperature and Humidity Sensor Draft
A project log for PhotonHome - AC Power IoT Homebase
The PhotonHome is the next step in bringing the Photon environment to AC powered applications
sako0938sako0938 07/08/2015 at 18:010 Comments
Here is the draft for the DHT22 temp/humidity sensor board. This sensor was the original purpose for building this device. Next most important sensor to me is K-type thermocouple, as I want to make a toaster reflow oven.
