A Blue Peter style build that's as much simple arts and crafts as it is electronics. This is the TARDIS time's tables (rather than times tables). Use each Doctor's RFID card to solve multiplication sums and defeat the Daleks. This requires very little (or no) soldering, and all the parts are very common and cheap.
Although this build is based around a times tables test and a TARDIS, the same system can be used to create any quiz or game using RFID cards as the UI. For instance, you could create a geography quiz, where you've got to match the country card to the capital city.
There are two Arduino sketches to this build. As well as the actual game, there is a separate sketch for programming the RFID cards.
Images are Copyright (c) Tim Doyle 2014 and are used with permission. www.NakatomiInc.com
The Doctor Who series and characters appearing thereon are copyrighted by the BBC. The term "TARDIS" is trademarked by the BBC. The Daleks are trademarked by Terry Nation.
The build is complete. As you can now see in the gallery, we've finished making the box. It's very Blue Peter - a cardboard box and lots of sticky-backed plastic, but all the better for that. Here's Jack demoing it.
I've rebuilt the RFID and LCD components onto smaller breadboards that can be fitted directly into the cardboard box. I like this a lot as the breadboards are self adhesive, and you don't need to solder a custom board.
I'm waiting for my 10mm blue LED for the roof light, and I'm still exploring how to mount the speaker inside the case, and whether I should you a piezo.
Breadboard an Arduino Pro Mini onto a medium sized breadboard, along with a breadboard power supply. Wire the Arduino to power supply.
2
Step 2
Wire the SPI pins of the Arduino onto two other small breadboards. Add an extra wire onto one of the breadboards to select the RFID reader, and two wires to the other board, one for selecting the LCD and one for the SD Card reader. Add +5v and Ground wires to each of the small breadboards.
3
Step 3
Wire the RFID reader according the labels on your reader to one of the small breadboards. The reset line can be brought to Ground if you don't want to wire it in.
i like it
