Rain Water Automation
A system that uses automation to provide better water collection with less maintenance than traditional harvesting methods
We've developed an integrated, holistic solution for rainwater collection based on over a decade of experience living with rain water as our only source of water. Our system provides a simple, integrated solution to solve common challenges of rainwater collection systems. An existing system may benefit with fairly simple adaptations. New systems can be designed for improved functionality and aesthetics while potentially lowering the cost.
  • 1 × Arduino Nano Heart of the controller
  • 3 × Custom PCB Main circuit, switch module & remote water tight display
  • 1 × 4 relay circuit board To control valves and pumps
  • 25 × Various electrical components To complete the controller
  • 2 × Custom ABS panels To make mount everything in the enclosure
Tamara Gagliardi wrote 07/27/2015 at 07:16 point
Is there a description on how this solution works and the various parts that make up the system?
Currently working on: https://hackaday.io/project/4698-clouden
