Monadic Gates 0-9, Completed Schematic
A project log for Tern - Ternary Logic Circuits
A series of ternary logic gates and higher level components implemented in the real world.
Mechanical AdvantageMechanical Advantage 07/06/2015 at 03:450 Comments
Okay, I've re-tested each gate from 0-9 and documented them properly. This "final" version includes a correction to one of the gates (I don't recall which) so it should definitely be used instead of earlier versions of the schematics. The remainder of the gates will be posted in the near future. Here's the link.
