Monadic Gates, Take 4
A project log for Tern - Ternary Logic Circuits
A series of ternary logic gates and higher level components implemented in the real world.
mechanical-advantageMechanical Advantage 06/24/2015 at 17:150 Comments
I've revised the A,N, and T monadic gates to simplify them and reduce them to a single LM319. Here's the diagram.
This leaves only 2 more monadic gates to go and I think I've got those under control. Then I can move on to 2-input gates like AND, OR, NAND, NOR, XOR, etc.
