Monadic Gates Completed
A project log for Tern - Ternary Logic Circuits
A series of ternary logic gates and higher level components implemented in the real world.
mechanical-advantageMechanical Advantage 06/26/2015 at 17:140 Comments
I've worked out the last two monadic gates (7 and F) using the LM319. In both cases it requires the use of three gates meaning two separate 319's. That makes these two the most complicated of the monadic gates (though still very simple). Here's the diagram.
