Just When You Think You Are Soooo Smart...
A project log for Tern - Ternary Logic Circuits
A series of ternary logic gates and higher level components implemented in the real world.
mechanical-advantageMechanical Advantage 07/29/2015 at 06:070 Comments
Sometimes you just have to do things the hard way. Or at least I do. I was thinking over different ways to arrange the 5 gate(simple inverter) and P gate(buffer) to possibly arrive at the XOR and XNOR gates. Then is struck me. Why the heck am I building buffers?!?! You stick a 0 in, you get a 0. Duh.
I just built a Max gate using nothing but two diodes. I guess I'll have to test the 8 two-input gates I already built and re-do the schematics replacing all the P gates with diodes. That sure does make things easier in the long run.
I guess I was just so busy patting myself on the back that I totally bypassed the obvious ;)
