Volkswagen CAN BUS Gaming
Controlling a VW CAN BUS dashboard of a Polo 6R with an Arduino and a CAN BUS shield using the Telemetry API of Euro Truck Simulator 2
Ever wanted to play a car/truck simulator with a real dashboard on your PC? Me too! I'm trying to control a VW Polo 6R dashboard via CAN Bus with an Arduino Uno and a Seeed CAN Bus Shield. Inspired by Silas Parker.
[!!!] PLEASE NOTE [!!!]
This project only works with an instrument cluster of a Volkswagen Polo 6R.
I can't give you any help when you try out this project with other instruments from different manufacturers, as every company has their own CAN BUS protocol.
I use this dashboard in combination with a Logitech G27 wheel and coded a program for it. Just come round to my other Hackaday Project: https://hackaday.io/project/7059-logitech-g27-compatibility-tool
Click on one of the following Links to navigate through the project page:
All Project LogsAll CAN Codes
Project Page @ Seeed Studios
Silas Parker's Blog
YouTube ChannelYouTube Playlist
Download CenterSources
Supporters and Sponsors
See the project in action:
German demonstration: http://youtu.be/BZKrnzsYgRA
VW Speedometer Adapter.zip
Source of the circuit board used to connect the instrument cluster to the arduino
Zip Archive - 676.76 kB - 12/19/2017 at 09:13
Download
VWCode3.0_static.ino
Newest version of test sketch. For Arduino with Seeed CAN BUS Shield and installed libraries.
ino - 12.51 kB - 12/30/2016 at 15:31
Download
VWRadio_Setup.exe
The software used in my latest videos. It simulates an RNS310 from VW and plays online radio stations over the Internet (m3u-Streams and RTMP://) and also plays Windows Media Playlists (WPL file format). You can also visit some webpages (like maps for games) with it. Have fun. This file is a WinRAR-self-extracting archive. Just double-click it and install it. For support, or feedback please PM me.
x-msdownload - 16.04 MB - 04/06/2016 at 21:50
Download
3D-Print Radio-Case.stl
3D-Print Radio-Case (STL 3d-printable Sketch)
- 30.43 MB - 12/24/2015 at 14:30
Download
3D-Print Radio-Case.123dx
3D-Print Radio-Case (Autodesk 123D Design Project File)
- 4.68 MB - 12/24/2015 at 14:30
Download
View all 8 files
View all 7 components
  • Circuit Board Source online
    Leon Bataille12/19/2017 at 09:16 0 comments
    Hi,
    I just uploaded the source files for the circuit board which connects the instrument cluster with the CAN-BUS Shield. You can find it in the Download section of this project.
    I hope this clears the questions about connection problems in the comments.
    I wish you all merry christmas and nice holidays!
  • New Version of VWRadio available (v1.2.1)
    Leon Bataille06/12/2017 at 14:55 0 comments
    I've just released a newer version for the VWRadio software.
    I fixed several small bugs. Especially the loop after the first launch without a prior configuration file has been fixed.
    There's now the option to enable a graphic visualization for music playback in the lower left corner.
    You can now also shut down your computer within the program. Therefore you have to go to the settings menu and click on exit. There you're can choose either to exit the program or to completely shut down your PC. I'll show you this feature in a future video. But at the moment it's a surprise for what I implemented it in the software.
  • Building a dashboard desk
    Leon Bataille06/09/2017 at 17:12 1 comment
    Hi there.
    It's been a long time since the last update.
    I'm back with some great news and some exciting plans.
    At the moment I'm building a new desk out of an Polo 6R dashboard. All buttons of the dashboard shall be used as controller in ETS2 and other simulation games.
    Even the Navigation System will display the map of the game (at least that's my goal).
    So here're some pictures of my new sub-project:
  • Creating an automatic Install and Setup Tool
    Leon Bataille05/08/2017 at 11:39 0 comments
    I'm in the process of building an Installation and Setup Tool for those of you, who wanted a detailed instruction on how to set everything up. This software does the job for you!
    I hope to complete this Setup Tool as fast as I can.
    Here's already a screenshot (You can manually choose the packages which you want to install)
  • New Demo-Sketch for Dashboard
    Leon Bataille12/30/2016 at 15:32 3 comments
    Hi!
    Just as promised a few days ago: Here's the new version of the test sketch.
    It contains more CAN BUS functions (such as much more LEDs to switch on or off) and is completely rewritten for a better structure and easier usage.
    These are the LEDs you can manually turn on or off in the sketch
    There's also a new section where you can setup a userdefined setup for testing your dashboard's functions!
    You find the new sketch in the download section of this project,
    or directly here.
    Best regards, and a happy new year!
  • More dashboard functions found
    Leon Bataille12/27/2016 at 21:20 2 comments
    Happy Holidays to all of you!
    The last few days I worked pretty hard on finding new functions of some CAN Commands for the dashboard!
    New functions I found:
    • Battery low warning
    • Fog Light
    • High Beam
    • ABS signal
    • Seat Belt warning
    • Hand brake
    • Low tire pressure warning
    • Offroad mode
    • Diesel particle filter
    • Diesel preheater
    • Water temperature alarm
    I also rewrote the hole demo script with more explanations and comments. The speed needle should also be more accurate (but sadly still not perfect yet)
    I will release the new demo source code in the next few days, so stay tuned.
    And I wish all of you a happy new year!
  • It's been a while
    Leon Bataille07/27/2016 at 11:36 5 comments
    After moving to antother city and my exams there's now time again for hackin'!
    So expect frequent updates from now on.
    I've bought a real dashboard from a VW Polo 6R and I want to build something like a desk out of it. So you can play great racing games and work on it.
    I'm really excited about the next months and hope to get everything working :D
  • Dashboard Photoshoot
    Leon Bataille04/18/2016 at 11:45 0 comments
    Hello Tech-Enthusiasts!
    I just updated the thumbnails for this project. Therefore I got help in a photo studio to take some better profile pics. I hope you enjoy them!
  • 100 Followers!
    Leon Bataille04/11/2016 at 18:07 0 comments
    Thank you for your awesome support!
    We've reached the big mark of one hundred followers!
    This is just awesome! Thank you.
  • RNS310 Simulator software available for Download
    Leon Bataille04/06/2016 at 21:59 0 comments
    Hi!
    I used the last time to build a Windows software which simulates an VW Radio (RNS 310).
    You can find it in the download section of this project page. Or here
    I coded it from scratch and I even drew every single image by myself. So please don't hesitate to PM me for bug reports :D
    For support or feedback please also write me an PM.
    Thanks!
View all 48 project logs
  • 1
    Step 1
    Known CAN Codes so far:
    For CAN Codes please visit the Sources-Page.
  • 2
    Step 2
    Instruction Video:
  • 3
    Step 3
    Arduino Source Code:
    //Volkswagen CAN BUS Gaming
    //Test Sketch v3.0
    //(C) by Leon Bataille 2015-2016
    //Hackaday Project Page: https://hackaday.io/project/6288-volkswagen-can-bus-gaming
    //Sketch information #DO NOT REMOVE!
    String game = "VW Static v3.0";
    String vendor = "Leon Bataille";
    //END Sketch information
    //For individual setup scroll down to the section MAIN CONFIGURATION
    //Libraries
    #include <mcp_can.h>            //CAN Bus Shield Compatibility Library
    #include <SPI.h>                //CAN Bus Shield SPI Pin Library
    #include <Servo.h>              //Library for Controlling Servos
    #include <Wire.h>               //Extension Library for measuring current
    #include <LiquidCrystal_I2C.h>  //Libraries for controlling LC Displays
    #include <LCD.h>
    #include <LiquidCrystal.h>
    //Definition
    #define lo8(x) ((int)(x)&0xff)
    #define hi8(x) ((int)(x)>>8)
    //Variables (Dashboard LEDs)
    int high_beam = 13;
    int fog_beam = 12;
    int park_brake = 11;
    //Variables (VW Dashboard Adapter)
    int LEFT_INDICATOR  = A0;
    int RIGHT_INDICATOR = A1;
    int PARKING_BREAK   = A2;
    int FUEL_WARNING    = A3;
    //Variables (Dashboard Functions)
    int turning_lights = 3;
    boolean turning_lights_blinking = true;
    int turning_lights_counter = 0;
    int temp_turning_lights = 0;
    boolean backlight = false;
    int oilpswitch = 8;
    int pack_counter = 0;
    boolean add_distance = false;
    int drive_mode = 0;
    int distance_multiplier = 2;
    boolean oil_pressure_simulation = true;
    boolean door_open = false;
    boolean clutch_control = false;
    int temp_clutch_control = 0;
    boolean check_lamp = false;
    int temp_check_lamp = 0;
    boolean trunklid_open = false;
    int temp_trunklid_open = 0;
    boolean battery_warning = false;
    int temp_battery_warning = 0;
    boolean keybattery_warning = false;
    int temp_keybattery_warning = 0;
    int lightmode = 0;
    boolean seat_belt = false;
    int temp_seat_belt = 0;
    int engine_control = 0;
    int temp_dpf_warning = 0;
    boolean dpf_warning = false;
    boolean light_fog = false;
    int temp_light_fog = 0;
    boolean light_highbeam = false;
    int temp_light_highbeam = 0;
    boolean signal_abs = false;
    boolean signal_offroad = false;
    boolean signal_handbrake = false;
    boolean signal_lowtirepressure = false;
    boolean signal_dieselpreheat = false;
    boolean signal_watertemp = false;
    int temp_signal_abs = 0;
    int temp_signal_offroad = 0;
    int temp_signal_handbrake = 0;
    int temp_signal_lowtirepressure = 0;
    int temp_signal_dieselpreheat = 0;
    int temp_signal_watertemp = 0;
    //Variables (Speed and RPM)
    int speed = 0;
    byte speedL = 0;
    byte speedH = 0;
    int rpm = 0;
    short tempRPM = 0;
    byte rpmL = 0;
    byte rpmH = 0;
    int distance_adder = 0;
    int distance_counter = 0;
    //Variables LCD
    LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Addr, En, Rw, Rs, d4, d5, d6, d7, backlightpin, polarity
    //Variables CAN BUS
    /* the cs pin of the version after v1.1 is default to D9
    v0.9b and v1.0 is default D10 */
    const int SPI_CS_PIN = 9;
    MCP_CAN CAN(SPI_CS_PIN);  // Set CS pin
    //Setup Configuration
    void setup()
      //Initialize LCD
      lcd.begin(16,2);
      lcd.backlight();
      showLCD("VW Dashboard","by Leon Bataille");
      delay(2000);
      showLCD("VW Dashboard","booting...");
      //Define Dashboard LEDs as Outputs
      pinMode(high_beam, OUTPUT);
      pinMode(fog_beam, OUTPUT);
      pinMode(park_brake, OUTPUT);
      pinMode(oilpswitch, OUTPUT);
      //Visual Start Sequence on Dashboard
      digitalWrite(high_beam, HIGH);
      digitalWrite(fog_beam, HIGH);
      digitalWrite(park_brake, LOW);
      digitalWrite(PARKING_BREAK, HIGH);
      delay(500);               // wait for a second
      digitalWrite(high_beam, LOW);
      digitalWrite(FUEL_WARNING, HIGH);
      digitalWrite(PARKING_BREAK, LOW);
      delay(500);
      digitalWrite(FUEL_WARNING, LOW);
      digitalWrite(LEFT_INDICATOR, HIGH);
      digitalWrite(RIGHT_INDICATOR, HIGH);
      digitalWrite(fog_beam, LOW);
      delay(500);
      digitalWrite(LEFT_INDICATOR, LOW);
      digitalWrite(RIGHT_INDICATOR, LOW);
      //Begin with Serial Connection
      Serial.begin(115200);
      //Show Sketch information on LCD
      showLCD(game,"by "+vendor);
      //Begin with CAN Bus Initialization
    START_INIT:
        if(CAN_OK == CAN.begin(CAN_500KBPS))                   // init can bus : baudrate = 500k
            Serial.println("CAN BUS Shield init ok!");
        else
            Serial.println("CAN BUS Shield init fail");
            Serial.println("Init CAN BUS Shield again");
            delay(100);
            goto START_INIT;
    //Reload LC Display
    void showLCD(String line1,String line2)
      lcd.clear();
      lcd.setCursor(0, 0);
      lcd.print(line1);
      lcd.setCursor(0, 1);
      lcd.print(line2);
    //Send CAN Command (short version)
    void CanSend(short address, byte a, byte b, byte c, byte d, byte e, byte f, byte g, byte h)
      unsigned char DataToSend[8] = {a,b,c,d,e,f,g,h};
      CAN.sendMsgBuf(address, 0, 8, DataToSend);
    //fuel gauge (0-100%)
    void Fuel(int amount)
      pinMode(2, INPUT);
      pinMode(3, INPUT);
      pinMode(4, INPUT);
      pinMode(5, INPUT);
      pinMode(6, INPUT);
      pinMode(7, INPUT);
      if (amount >= 90)
        pinMode(2, OUTPUT);
        digitalWrite(2, LOW);
        return;
      if (amount >= 75)
        pinMode(3, OUTPUT);
        digitalWrite(3, LOW);
        return;
      if (amount >= 50)
        pinMode(4, OUTPUT);
        digitalWrite(4, LOW);
        return;
      if (amount >= 25)
        pinMode(5, OUTPUT);
        digitalWrite(5, LOW);
        return;
      if (amount >= 10)
        pinMode(6, OUTPUT);
        digitalWrite(6, LOW);
        return;
      if (amount >= 0)
        pinMode(7, OUTPUT);
        digitalWrite(7, LOW);
        return;
    //Loop
    void loop()
      //MAIN SETUP FOR OPERATION
      //Set constant speed and RPM to show on Dashboard
      speed = 0;                        //Set the speed in km/h
      rpm = 800;                        //Set the rev counter
      Fuel(30);                          //Set the fuel gauge in percent
      //Set Dashboard Functions
      backlight = true;                  //Turn the automatic dashboard backlight on or off
      turning_lights = 0;                //Turning Lights: 0 = none, 1 = left, 2 = right, 3 = both
      turning_lights_blinking = false;   //Choose the mode of the turning lights (blinking or just shining)
      add_distance = false;              //Dashboard counts the kilometers (can't be undone)
      distance_multiplier = 2;           //Sets the refresh rate of the odometer (Standard 2)
      signal_abs = false;                //Shows ABS Signal on dashboard
      signal_offroad = false;            //Simulates Offroad drive mode
      signal_handbrake = false;          //Enables handbrake
      signal_lowtirepressure = false;    //Simulates low tire pressure
      oil_pressure_simulation = true;    //Set this to true if dashboard starts to beep
      door_open = false;                 //Simulate open doors
      clutch_control = false;            //Displays the Message "Kupplung" (German for Clutch) on the dashboard's LCD
      check_lamp = false;                //Show 'Check Lamp' Signal on dashboard. B00010000 = on, B00000 = off
      trunklid_open = false;             //Simulate open trunk lid (Kofferraumklappe). B00100000 = open, B00000 = closed
      battery_warning = false;           //Show Battery Warning.
      keybattery_warning = false;        //Show message 'Key Battery Low' on Display. But just after first start of dashboard.
      light_fog = false;                 //Enable Fog Light
      light_highbeam = false;            //Enable High Beam Light
      seat_belt = false;                 //Switch Seat Betl warning light.
      signal_dieselpreheat = false;      //Simualtes Diesel Preheating
      signal_watertemp = false;          //Simualtes high water temperature
      dpf_warning = false;               //Shows the Diesel particle filter warning signal.
      //Conversion Speed
      speed = speed / 0.0075; //KMH=1.12 MPH=0.62
      //Conversion Low and High Bytes
      speedL = lo8(speed);
      speedH = hi8(speed);
      tempRPM = rpm*4;
      rpmL = lo8(tempRPM);
      rpmH = hi8(tempRPM);
      if (add_distance == true)
        distance_adder = speed * distance_multiplier;
        distance_counter += distance_adder;
        if (distance_counter > distance_adder) { distance_counter = 0; }
      if ( oil_pressure_simulation == true)
      //Set Oil Pressure Switch
        if (rpm > 1500) {
          digitalWrite(oilpswitch, LOW);
        else {
          digitalWrite(oilpswitch, HIGH);
      /*Send CAN BUS Data*/
      //Immobilizer
      CanSend(0x3D0, 0, 0x80, 0, 0, 0, 0, 0, 0);
      //Engine on and ESP enabled
      CanSend(0xDA0, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00);
      //Enable Cruise Control
      //CanSend(0x289, 0x00, B00000001, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00);
      //Dashboard Functions
      //Turning Light blinking
      if (turning_lights_blinking == true)
        if (turning_lights_counter == 15)
          temp_turning_lights = turning_lights;
          turning_lights_counter = turning_lights_counter + 1;
        if (turning_lights_counter == 30)
        else
      else
      //Check main settings
      //DPF
      if (dpf_warning == true) temp_dpf_warning = B00000010;
      else temp_dpf_warning = B00000000;
      //Seat Belt
      if (seat_belt == true) temp_seat_belt = B00000100;
      else temp_seat_belt = B00000000;
      //Battery Warning
      if (battery_warning == true) temp_battery_warning = B10000000;
      else temp_battery_warning = B00000000;
      //Trunk Lid (Kofferraumklappe)
      if (trunklid_open == true) temp_trunklid_open = B00100000;
      else temp_trunklid_open = B00000000;
      //Check Lamp Signal
      if (check_lamp == true) temp_check_lamp = B00010000;
      else temp_check_lamp = B00000000;
      //Clutch Text on LCD
      if (clutch_control == true) temp_clutch_control = B00000001;
      else temp_clutch_control = B00000000;
      //Warning for low key battery
      if (keybattery_warning == true) temp_keybattery_warning = B10000000;
      else temp_keybattery_warning = B00000000;
      //Lightmode Selection (Fog Light and/or High Beam)
      if (light_highbeam == true) temp_light_highbeam = B01000000;
      else temp_light_highbeam = B00000000;
      if (light_fog == true) temp_light_fog = B00100000;
      else temp_light_fog = B00000000;
      lightmode = temp_light_highbeam + temp_light_fog;
      //Engine Options (Water Temperature, Diesel Preheater)
      if (signal_dieselpreheat == true) temp_signal_dieselpreheat = B00000010;
      else temp_signal_dieselpreheat = B00000000;
      if (signal_watertemp == true) temp_signal_watertemp = B00010000;
      else temp_signal_watertemp = B00000000;
      engine_control = temp_signal_dieselpreheat + temp_signal_watertemp;
      //Drivemode Selection (ABS, Offroad, Low Tire Pressure, handbrake)
      if (signal_abs == true) temp_signal_abs = B0001;
      else temp_signal_abs = B0000;
      if (signal_offroad == true) temp_signal_offroad = B0010;
      else temp_signal_offroad = B0000;
      if (signal_handbrake == true) temp_signal_handbrake = B0100;
      else temp_signal_handbrake = B0000;
      if (signal_lowtirepressure == true) temp_signal_lowtirepressure = B1000;
      else temp_signal_lowtirepressure = B0000;
      drive_mode = temp_signal_abs + temp_signal_offroad + temp_signal_handbrake + temp_signal_lowtirepressure;
      //Send CAN data every 200ms
      pack_counter++;
      if (pack_counter == 20)
        //Turning Lights 2
        CanSend(0x470, temp_battery_warning + temp_turning_lights, temp_trunklid_open + door_open, backlight, 0x00, temp_check_lamp + temp_clutch_control, temp_keybattery_warning, 0x00, lightmode);
        //Diesel engine
        CanSend(0x480, 0x00, engine_control, 0x00, 0x00, 0x00, temp_dpf_warning, 0x00, 0x00);
        ///Engine
        //CanSend(0x388, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00);
        //Cruise Control
        //CanSend(0x289, 0x00, B00000101, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00);
        pack_counter = 0;
      //Motorspeed
      CanSend(0x320, 0x00, (speedL * 100), (speedH * 100), 0x00, 0x00, 0x00, 0x00, 0x00);
      //RPM
      CanSend(0x280, 0x49, 0x0E, rpmL, rpmH, 0x0E, 0x00, 0x1B, 0x0E);
      //Speed
      CanSend(0x5A0, 0xFF, speedL, speedH, drive_mode, 0x00, lo8(distance_counter), hi8(distance_counter), 0xad);
      //ABS
      CanSend(0x1A0, 0x18, speedL, speedH, 0x00, 0xfe, 0xfe, 0x00, 0xff);
      //Airbag
      CanSend(0x050, 0x00, 0x80, temp_seat_belt, 0x00, 0x00, 0x00, 0x00, 0x00);
      //Wait a time
      delay(20);
View all 3 instructions
apichlinski wrote 04/22/2019 at 13:17 point
Hi Leon,
Thank you for sharing this projekt! I have strange issue with my speedometer: after 20-30 sec from start i have very loud sound. What's happening?
heiner.pahlings wrote 10/31/2018 at 13:50 point
Hi,
I do have a Porsche 911 electrified, it is from 1998 so a little before CAN-BUS was introduced. Now I try to get some Engine noise added. As I have a Android based Car radio and a nice app found (voom voom) I would be able to emulate Engine sound. It works best if the Car Radio would connect to CAN-BUS to detect the RPM. Here I use the electronic available RPM signal of my engine controller and intend via CAN-BUS schield to make this as CAN Bus signal available for the radio. and for that you written code is quite helpful.
there is one thing I do not get. Why do you multiply the rpm input you have by 4?
Many Thanks for your project, and Many Thanks for your reply.
Ahmed lz wrote 05/14/2018 at 17:56 point
hi , i want to control my polo 6 lights with arduino (high beam , low beam , blikers doors lock ....) but i can't find thier canbus adresse i wish you can help me please answer yes or no thanks anyway
Anthony wrote 02/26/2018 at 12:55 point
Can you show dumps of messages with ID 0x320 coming from panel? I'm trying to run with VW dashboard, but can't adjust speedometer. Messages with ID 0x1A0 and 0x5A0 affects speedometer, but not stable, in messages 0x320 I see error bit in speed calculation.
Tai Bui wrote 02/07/2018 at 20:43 point
I got this error message in compiling tne sketch :
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\Tai\Documents\VWCode3.0_static\VWCode3.0_static.ino:23:33: fatal error: LCD.h: No such file or directory
 #include <LCD.h>                                                 ^
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Please help.
gautier.p62 wrote 01/08/2018 at 10:13 point
Hi Leon!
I have a question.
How is possible to use
int high_beam = 13;
int fog_beam = 12;
ports for LED-s, if this pins are used by the SPI bus for communication with CAN-BUS?
Udo Schneider wrote 08/30/2017 at 18:17 point
What's the newest (best?) source for wiring? On first glance the fritzing diagram is not identical to Is0-Mick's diagram ... and both do contain things which didn't work on the dashboard I'm using. Maybe (the source for) the PCB might be a good reference - but where to get that?
Leon Bataille wrote 12/19/2017 at 09:18 point
Hi! I just uploaded the source files of the circuit board.
lego wrote 01/05/2018 at 17:45 point
downloaded the updated diagram, found out it's made with autodesk eagle which in order to use i need an account, any chance for an exported file like .pdf or something that doesn't require to create accounts?
Leon Bataille wrote 01/05/2018 at 18:11 point
Oh I see. Apparently it was Freeware a year ago. Could you please try it with the free version by Cadsoft? http://ftp.cadsoft.de/freeware.htm
lego wrote 01/07/2018 at 09:43 point
the Cadsoft link no longer works, it redirects to the same autodesk eagle which you have to make an account.
Leon Bataille wrote 01/07/2018 at 10:10 point
OK, I think my PC had the original download page in cache. I‘ll make an PDF of the schematic and the board. Sorry for this misunderstanding.
Anthony Whittle wrote 07/27/2017 at 13:15 point
Hello again,
When will the installation setup tool be available?
Thanks
Anthony Whittle wrote 07/07/2017 at 17:46 point
Hi,
Does it work with the petrol version dash?
Thanks
Leon Bataille wrote 07/11/2017 at 18:58 point
Should also work with the petrol version, yes.
Steph Geiselh. wrote 04/28/2017 at 10:00 point
Hey Leon,
I have seen a wiring diagram for the engine temperature and the fuel gauge on a photo.
Can we see this circuit diagram in more details?? Thanks :)
Leon Bataille wrote 07/11/2017 at 18:59 point
Yes of course :) Did you mean the outside temperature insted of the engine temp.?
Tom wrote 04/17/2017 at 09:14 point
Hello,
I'm trying to bring this project to life on my own, however - it seems like the cluster isn't communicating with Arduino.
Have you removed a 62k resistor from can bus shield?
Regs,
Tom
Leon Bataille wrote 07/11/2017 at 19:01 point
no, i didn't remove any parts from the can bus shield. however it could be that newer versions of the can bus shield are little bit different. especially the CS pin could have changed. I think mine has D9 as CS pin and newer have D10. but I'm not sure at the moment.
Tom wrote 07/12/2017 at 06:46 point
Hi Leon!
Thank you for the reply. Indeed - mine shield has CS pin on D10, but that wasn't the case. It turned out that on my shield CAN high an low pins are swapped (pins itself are fine, but the pins' description on the shield are contrariwise), so I've got it working :)
Unfortunately - I couldn't get the Passat's B6 Instrument to work (speed gauge was jumping for few seconds and after that - it's been turning off), so I've took a instrument cluster out from... Fiat Panda and it's working perfect ;)
Thank you very much for this project :)
Best regs
Tom
lego wrote 04/16/2017 at 12:51 point
i've got the tacho, the arduino and the canbus shield, got the code on the arduino but when i go into ets 2 nothing happens. the rpm needle stays at 800 rpm and that's it.
could it be from the plugin? maybe they changed something in the telemetry.
Silas's plugin is 3 years old...
Leon Bataille wrote 07/11/2017 at 19:02 point
Oh this would be not godd (*panic). I will double check this and reply when I know more about it. Thanks for the info.
Felix wrote 03/15/2017 at 09:10 point
I've purchased the exact same tacho from a 6R with the same pinout and all. But when I connect it it says no key and beeps then no function with any of the can bus calls. Do you have any suggestions to bypass this or what might be the issue? How do you connect the immobiliser pins or is it not necessary to touch?
Leon Bataille wrote 07/11/2017 at 19:04 point
The tacho should work even when it says "no key". Mine tells me the same. Did you upload my newer script or did you try to send one single command?
alex wrote 08/09/2018 at 22:03 point
hi! I have the same issue at the moment with the “no key found” message. It seems that if I send any CAN message of the steering wheel buttons to go to the next MFD display, nothing bypasses the “no key found” message.
Do you have any suggestion for this?
Thanks
animireddysaip wrote 01/26/2017 at 11:33 point
Hie i am a student trying to build a two way communication (using can bus protocol) between two arduino's which have some sensors and actuators on them,
can you please help me with the code required for sending and receiving the sensor values on CAN BUS protocol. (atleast where to refer)
Leon Bataille wrote 07/11/2017 at 19:06 point
Hi, sorry for my late replay. But I hope it's not too late ;-). There are very useful examples for the CAN BUS protocol in the Arduino library of the Seeedstudio CAN BUS Shield. Just open Arduino IDE, import the library and click on File>Examples>CAN.
There should be everything you need.
vitecd wrote 01/24/2017 at 09:18 point
wiring diagram has some missing components
Leon Bataille wrote 01/24/2017 at 10:45 point
thanks for the info. yes the diagram is out of date.
I'll make a new one as soon as i can.
bigvicproton wrote 01/08/2017 at 03:35 point
Perhaps I am missing something, but I have the Silas Parker plugin installed and telemetry is working.  Compiled on the Arduino and running RMP goes to 800, so I know the CanBus Shield is talking to the cluster.  Yet when playing ETS2 it is not talking to the cluster.  What am I doing wrong?
Leon Bataille wrote 01/24/2017 at 09:44 point
Hi, did you check the config file inside the plugin folder of ETS2? (i.e. C:\Program Files\Euro Truck Simualtor 2\bin\win_x86\plugins\dash_plugin.txt)
You have to configure the COM Port of your Arduino inside this file.
Best regards,
Leon
Jeroen van der Velden wrote 01/05/2017 at 14:18 point
Hi Leon, I lost my board schematic you send me along with your Board. Could you please send me a copy? Best Regards, Jeroen
bigvicproton wrote 12/21/2016 at 14:23 point
Hi Leon,  Could you show us the code you used to get the gas gauge working?
trandi wrote 10/25/2016 at 22:24 point
Hi Leon, I'm trying to replicate your work but using a Skoda Octavia 2002 instrument cluster and a LM3S8962 dev board from Texas Instruments (which has a CAN peripheral included).
I could immediately turn on / off a few lights and the RPM indicator (https://goo.gl/photos/JdxRyuY42Auv7dXZ9 ) but now I'm completely stuck with the Speed indicator and/or the other 2 smaller ones (oil temperature and petrol tank).
I've obviously tried you codes for the speed but they don't seem to work... any other idea ?
Dan
jsfrederick2011 wrote 06/07/2016 at 11:25 point
hey leon is there a way to PM you?
Leon Bataille wrote 06/07/2016 at 14:26 point
yes of course, just click on my name and write me an PM :)
