3D-printed display frame for touchscreen
A project log for CAN BUS Gaming Simulator
Controlling a VW CAN BUS dashboard of a Polo 6R with an Arduino and a CAN BUS shield using the Telemetry API of Euro Truck Simulator 2
leon-batailleLeon Bataille 09/15/2015 at 07:220 Comments
A while ago I mentioned that I want to add a touchscreen to the project in combination with the RNS software I programmed.
As I also wanted to put all circuit boards into a box together with the display, this is the first big step for building this box or case.
You've already seen the plan of the display frame, but this is a photo of the printed version. Remember: I still have to polish it a little bit...
