Maybe sourced the board...
A project log for Smart watch Journal
Modify/make a smartwatch with a user facing camera to record those all important logs when you're lost in space
j0z0r-pwn4tr0nj0z0r pwn4tr0n 04/22/2017 at 03:060 Comments
I backed the indiegogo for the Lichee Pi Zero, and hopefully it will be arriving in the next month or so. If you haven't heard about it, it's basically an SD card sized, breadboardable Pi Zero clone. Here's some links:
https://www.indiegogo.com/projects/licheepi-zero-6-extensible-linux-module-on-finger-wifi-diy#/
https://liliputing.com/2017/03/lichee-pi-zero-tiny-linux-computer-module-6-crowdfunding.html
https://hackaday.io/project/20181-lichee-pi-zero
The form factor is perfect, and it already has support for the types of small cameras I would need to be running.
I'll start fleshing out this project more as I do the research and design
