Initial Log Entry
A project log for Foofy Weensy - Teensy + ESP8266
A Teensy development board which includes a ESP8266 and Lipo charger.
Stephen EdwardsStephen Edwards 06/29/2015 at 01:440 Comments
Moved from Description was in the wrong place (Doh!)
Currently tuning the Wifi Antenna. My First PCB Trace Antenna was incorrect as I mis calculated the Feed Trace Width and Antenna length. But the Ceramic antenna saved the day.
Time to search for someone with a Network Analyser or Spectrum Analyser that won't charge the Earth to use it, or find some Low Cost 2.4Ghz add on for my Oscilloscope.
