Hardware Accelerated Lower Resolutions: Working!
A project log for VGA Graphics Over SPI and Serial - VGATonic
640x480 (and 848x480!) Color VGA Video Card for Microcontrollers and Single Board Computers
pkPK 06/26/2015 at 07:330 Comments
I've got some good after-midnight Pacific Time news for you: hardware acceleration of lower resolutions is working!!! (Macrocell count: 137/144. Pushing it...)
This is a great result for slower-speed parts, since you can still get a usable resolution out of any VGA monitor you've got without forcing a "slide show" through 640x480 resolution.
Here are the stats for 8 bit color; bpS is 'bits per Screen'
So, if you only had 2 MHz SPI on your part, you were staring at .8 frames per second... but if you drop down to the hardware accelerated 160x120 you can now support 13!
Here's a quick snap of a desktop at 80*60, for the laughs and the proof (bonus: can you identify the single board computer at this puny resolution? I'll release a new Linux framebuffer driver drop after the VHDL is good!):
Pretty funny, eh? Well... I thought it was funny, anyway.
(Side note: everything is working beutifully in Linux; I can do my resolutions changes with 'fbset -fb /dev/<mine> -xres xxx -yres yyy' just fine. Props, too, for xserver dealing with 80x60...)
And the theory:
Rows are easy; for each drop in resolution, double the number of rows we 'loiter on'.
480 Rows = 1 Clock
240 Rows = 2 Clock
120 Rows = 4 Clocks
60 Rows  = 8 Clocks
Don't you love powers of two?
Columns are a little trickier - I had to find a way to skip ahead, but the 'loitering' part isn't that bad - for each drop in resolution, I shift the LSB. I'll write out the bits so you can see the pattern:
640 = 0000 0010 1000 0000
320 = 0000 0001 0100 0000
160 = 0000 0000 1010 0000
80  = 0000 0000 0101 0000
That beautiful shift is what allows us to force VGATonic to sit on a pixel fo a few clocks before shifting. I'll upload the VHDL soon, hopefully with color depth features added.
You know, if I can fit them into 7 macrocells.
