I've redeveloped my robotic scythe.
My project's aim is to develop a lawnmower that is able to mow lawn that hasn't been mowed before. (That is able to mow the tallest fucking grass :D )
New design and new ideas.
The orginal project was started about 3 years ago.
Details
We need a lawnmower which is can cut the higher weed also.
The conception about a 2+1 wheeled cutter.
- Vertical cutter - 3D local positioning - Wifi controll - automatic recharging
Components
1×
Drive block with MG996R
3D printed geared
1×
Drive controller with Digispark (Attiny85)
Digispark a micro sized controller. Used for wheel control (forward, turn, sense)
Hi, my main problem - what I recognise in lawnmower concepts - the jam and the bottom mounted rotating blades can't cut the higer grass and weeds. So, This lawnower will walk slowly and all days, and the hair-clippers format can cut the higher grasses without jam and without human help. My hair-clippers concept imagined with horizontal vibration (not exactly than the attached image)
I restarted the project and I have a new design.
