A project log for ROBOScythe (lawnmower for meadow)
from scratch ...
gabor-horvathGabor Horvath 06/30/2019 at 14:491 Comment
The ROBOScythe almost ready for use.
The new design based on VSLOT 20x20 extruded aluminium
The drive system based on two MG996 servos and GT2 pulleys. Side effect: I created a GT2 Pulley pack on Thingiverse.
The cutting equipment based on a BLDC motor. ( +ESC )
The blade has three wings with Robotic lawnmower razors (from OBI). You can use damilhead optionally
The ROBOScythe blade has a shield. And this shield built it with two pressure sensors.
The third "gear" is a tail and stabilizes the device.
And that's all together.
gicaho9147 wrote 08/05/2024 at 11:47 point
Hi! If you are still hesitating about this site, then I recommend you to pay attention to - review of site , because it is a really good review of this site. I myself only work on this site, because it has a lot of quality features that make the betting experience only better! I recommend it to you. Bye.
