Robotic lawnmower
for meadow
from scratch ...
I and my cousin started develop a lawnmower. The conception: mobile, automatic, programmable and funny.
We need a lawnmower which is can cut the higher weed also.
The conception about a 3 wheeled cutter.
- Vertical cutter
- 3D local positioning
- Wifi control
- 24h working
- automatic recharging
  • 1 × Drive block with MG996R 3D printed geared
  • 1 × Drive controller with Digispark (Attiny85) Digispark a micro sized controller. Used for wheel control (forward, turn, sense)
View all 2 project logs
Gabor Horvath wrote 07/03/2015 at 06:03 point
Hi, my main problem - what I recognise in lawnmower concepts - the jam and the bottom mounted rotating blades can't cut the higer grass and weeds.
So, This lawnower will walk slowly and all days, and the hair-clippers format can cut the higher grasses without jam and without human help.
My hair-clippers concept imagined with horizontal vibration (not exactly than the attached image)
Nathanael Ries wrote 07/02/2015 at 20:54 point
Do you think it might be safer to get rid of the rotating blades and instead duplicate the same concept used in electric hair clippers? http://businessfromhome.jasongregory.biz/en/video/dJU08S7Nx-E/How-stuff-works-Electric-motors-for-electric-shavers-rules-of-thermodynamics
