@SUFs negative voltage converter
A project log for Breadboard Widgets
A collection of widgets/adapters/breakouts to make prototyping easier/faster
Stefan LochbrunnerStefan Lochbrunner 08/04/2015 at 16:154 Comments
This is another one of @SUFs contributions, the original files of which can be found here. It's a negative voltage converter based on the Intersil ICL7660S and works quite well as you can see:
Here are the original schematic and board layout:
Since I mainly use Eagle, I remade it trying to stay as true to the original as possible.
However, since I wanted to make it as compact as possible (reducing the 'overhang' on the side of the pin headers) I ran into the problem of all the GNDs not connecting which required a slight rerouting to keep everything on one layer which is an advantage if you would like to etch it yourself (the GND vias are only redundancy).
... I can already feel the onset of feature creep caused by the empty bottom layer...
Update 2016-01-05:
I'm putting together another panel and wanted to include this board but since I'm not going to need ten of these I put a LD/LM1117 footprint on the back.
The board has footprints for resistors to adjust the voltage but if you use a fixed voltage device you can just short R2 to connect Adj to GND.
On Github as v3.
K.C. Lee wrote 08/04/2015 at 21:51 point
If you put the connector at the right hand side of C2 or upper right corner, then all the traces lines up.
SUF wrote 08/04/2015 at 22:16 point
But if you put the connector to the upper corner, the board will not fit into the breadboard vertically as it was designed for.
SUF wrote 08/04/2015 at 17:35 point
Hi Steve,
Just for the records, here is the picture of the original schematics:
Stefan Lochbrunner wrote 08/04/2015 at 18:05 point
Thanks, I replaced it above since the schematic symbol of the part I used had the pins in a strange order which was somewhat confusing. The package pinout was identical though.
