Backend
A project log for IoT to Feed the Next Billion
An opensource Web platform and cheap sensor hardware solution for the massification of Continuous-flow solution culture (hydroponics)
kestlerKestler 08/17/2015 at 18:520 Comments
Back-end is made up of a database, mosquitto an opensource Mqtt Broker (web Sockets enabled) and some phyton code to catch the broker data and storing it in the database, Mongo was selected as database since it can handle JSON structures with out parsing data, witch makes data handling faster. and it also provides us to integrate other non structured data like General Weather forecasts from Publicly available APIs and also to serve our data to the community via API of our own.
From Mosquitto to MongoDB
