system desing
A project log for IoT to Feed the Next Billion
An opensource Web platform and cheap sensor hardware solution for the massification of Continuous-flow solution culture (hydroponics)
kestlerKestler 08/17/2015 at 16:500 Comments
Overall System Desing:
-Nodes: ESP8266
Sensors: Water PH, Water Temperature, Water Salinity, Water Conductivity, Environmental Humidity, Temperature, pressure, PAR sensor, 3/4 water Flow sensor.
-Communications: Wifi
-Message Format: JSON
Protocol: MQTT
-Backend
Python
Pub/Sub: Mosquitto
DB: Mongo
-Front end:
python, Flask, nginx,
dashboards: Freeboard.io
