Sources Posted
A project log for CMOY Pro
My variation on the classic CMOY headphone amp design. Featuring better power filtering, quality negative rail IC, and a higher end opamp.
avrAVR 07/03/2014 at 19:290 Comments
The source files for the PCB have been posted to Github, you can get there by the link on the left. The PCB files might be incomplete because I had some second thoughts about the design, I will be updating this in the future when I get more time to put into it, expect the next update to be finished with a possible prototype fabricated.
