I found a wooden box at Hobby Lobby that almost perfectly fit what I wanted for the project. I cut a template for the screen size and drilled holes at two opposite corners of the screen area. Then, using a jig-saw, I cut out the screen area and fine tuned it with a wood rasp. I stained the box after extensive sanding with cherry stain.
John Leeman
