Mounting Monitor and Camera Preparation
A project log for PiBooth
RaspberryPi photo booth to help capture memories at your events.
john-leemanJohn Leeman 07/24/2015 at 01:360 Comments
The monitor is mounted using some M4 screws and plumbers tape. I also had to drill a hole for the IR sensor to be able to control the monitor. The remote is secured with some velcro, it's easily removed, but hopefully I won't lose track of it! I also prepared the area where the camera will be mounted. I drilled a hole and then used a jigsaw to make a slot for the PiCamera ribbon cable.
