Nano Bike Alarm
Back to project overview
An affordable RFID, motion-sensing, anti-theft alarm and GPS tracker for bicycles, e-bikes and other small vehicles. Based on Arduino
thoughtscape wrote 09/07/2018 at 06:40 point
weird, i posted here this morning but the post isn't showing up
Was curious if i could replace the RFID you use with one with more range  (1.5 metres or so) so that the alarm is deactivated when you are in range - like a key fob for newer cars. ..
Also, if i was to use the motorbike to recharge the battery,  where would i plug the 12v to 5v step down converter to? The auxiliary fuse in the fuse box?
Regards,
Mick
Zied wrote 04/23/2016 at 14:36 point
Hi Alpha Charlie,
I'm trying to build your project but I'm facing some difficulties. Especially with the MPU6050 interrupt attached to a FONA Shield + Arduino Uno.
Would you help me please ?
Thank you
Luis Javier wrote 09/01/2015 at 19:45 point
I can´t find the link to download the package and use the sketches. Can you please provide it to me?
Alpha Charlie wrote 09/01/2015 at 19:50 point
it's in the project links (which is on the left below 'team') but here is the link- https://github.com/alphacharlie/nano-bike-alarm
