Achievement unlocked: Thermal image on Pi
A project log for ElectricEye
Utilise off the shelf hardware and OSS to create a cheap thermal imaging camera for firefighting use
eded 06/30/2015 at 05:050 Comments
Finally had a chance to get the Lepton working with the Pi. Seems to have some dodgy on bootup tho; during the boot process it appears the Pi shoots something at the Lepton causing it to get locked up and require a reset. Obviously no good long term, will likely experiment with the newer model 2 Pi board and see if it also has this issue. Getting away from the RCA jack on the model 1 will be ideal anyway, as the newer 3.5 jack will result in far less cable clutter. May also look at the model2 rev A, as the lower power draw could be advantageous, tho lack of ethernet is slightly questionable from a convenience standpoint.
