LCD Backlight Control
A project log for Weather Station Zeta
An Arduino-powered weather station with an inside and an outside module.
Greg MillerGreg Miller 04/22/2014 at 20:520 Comments
By digging through the Arduino forum and some other sites, I've found that the secret to controlling the LCD's backlight via PWM is to use a transistor, resistor, and diode between the PWM pin and pin 16 on the LCD.
Now...onto XBEE!
