Arduino in BowlerStudio: A whole new perspective on 'full stack'
A project log for BowlerStudio: A robotics development platform
Make cooler robots, faster and with less effort.
Kevin HarringtonKevin Harrington 08/01/2016 at 14:180 Comments
BowlerStudio is a neat runtime for bootstrapping files out of git repos and quickly putting them to use. I have used this trick for CAD, for AI, and for kinematics control. Now i have finally added a new domain: Microcontroller code!. You can now push arduino firmwares as *part of your normal code flow* inside any bowler studio language. The trick is treading .ino files as a scripting language like any other, and then pushing it through the normal arduino command line interface.
I also ported over the DyIO firmware to arduino (fair warning it needs a Mega or Curie for the full IO controller code at the moment). I did get the standard bowler communication stack working on a standard arduino Uno, as well as extending it with arbitrary processing on the arduino called from a groovy script, loaded at runtime, and then called by the same script. Pretty trippy when you think about it...
I have added a few examples of this here: http://neuronrobotics.com/BowlerFullStack/C-Server/ These work in BowlerStudio 0.18.11 and up and need Arduino 1.5 or greater installed (all done by the ppa now, linux is the easy one)
