WIFI Color Sensor
WIFI enabled board that gets color components Red, Green and Blue of any material placed closed to the sensor and returns the values via TCP
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
WIFI enabled board that gets color components Red, Green and Blue of any material placed closed to the sensor and returns the values via TCP The 8266CS01 is a wifi enabled board that recognizes color components Red, Green and Blue of any material placed closed to the sensor. The reading of the color components is done via a TCP request to the board and the percentage color component values are returned in a JSON string. The sequence for reading is done by sending the following strings via TCP on port 9999: acquire (wait 5 seconds for acquisition to complete) read The return message is in JSON format as follows: {"RGB": [{ "Red:": "53", "Green": "23", "Blue:": "24"}]} each number representing the percentage of that color.
