Wifi Water Sensor
ESP8266 ESP-12 based WIFI Wireless Water Sensor. Detects presence of water (rain, etc).
ESP8266 ESP-12 WIFI Water Sensor detects presence of water.
It detects water presence in the sensor and sends a signal via WIFI using a pull mechanism via TCP protocol. The board can be configured via a web browser to connect to your wireless router. The board can be connected to a serial interface for debugging or reprogramming of the ESP8266 ESP-12, and comes with TX-RX connectors, reset and flash switches, making it flexible for experimenting and prototyping.
Tamara Gagliardi wrote 07/27/2015 at 07:24 point
Are there any further details as to set the hardware portion to use the MQTT protocol (http://horaciobouzas.com/2015/07/18/385/)? Im interested in understanding how, from the time the sensor capture the information, its then collected and aggregated in a central node/hub.
Currently working on: https://hackaday.io/project/4698-clouden
Horacio Bouzas wrote 07/12/2015 at 03:24 point
I can give more details on the project or you can go to www.horaciobouzas.com where I posted an article.
Gary wrote 07/11/2015 at 18:22 point
any follow up documents, scripts, code?
