WIFI Vibration Sensor
ESP8266 WIFI Vibration Sensor detects vibrations and sends them to a selectable IP address and TCP port
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
ESP8266 WIFI Vibration Sensor detects vibrations and sends them to a selectable IP address and TCP port ESP8266 based WIFI Vibration Sensor. It detects vibrations and sends a signal via WIFI to a selectable IP address and port number via TCP protocol. The board can be configured via a web browser to connect to your wireless router. The board can be connected to a serial interface for debugging or reprogramming of the ESP8266, and comes with TX-RX connectors, reset and flash switches, making it flexible for experimenting and prototyping.
