WIFI Movement Sensor
ESP8266 WIFI Movement Sensor detects movement and send signal to a server on a selectable IP address and TCP port
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
ESP8266 WIFI Movement Sensor detects movement and sends a signal to a server on a configurable IP address and TCP port
ESP8266 based WIFI Movement Sensor. It detects movements and sends a signal via WIFI to a server on port number 9999 via TCP protocol. The board can be configured via a web browser to connect to your wireless router. The board can be connected to a serial interface for debugging or reprogramming of the ESP8266, and comes with TX-RX connectors, reset and flash switches, making it flexible for experimenting and prototyping.
