First project progress update
A project log for Vinduino, a wine grower's water saving project
Monitoring soil moisture at different depths to determine when to irrigate, and - more importantly - how much water is needed. Save 25%!
reinier-van-der-leeReinier van der Lee 06/28/2015 at 19:190 Comments
Comparing two DIY gypsum sensor with a commercial Watermark SS200 sensor. With the Vinduino-R board, connected to the Thingspeak web site, I collected measurement data -every 4 minutes- for 3 weeks. I used soil taken from my vineyard (decomposed granite).
For the Watermark sensor, there is a lot of calibration data available to convert measured resistance to soil water potential.
Below is the comparison result. The Watermark shows more sensitivity in wet soil range. Both sensors show a temperature dependency. For watermark sensors, temperature compensation equation are well documented.
In summary: both sensors types look very usable for irrigation control.
In the vineyard we saw the first grape berries changing color, "Veraison" in grape grower terms.
The vineyard is looking well, even under the current reduced irrigation conditions.
