​Development Day 56
A project log for Arduino Enigma Machine Simulator
An Enigma Machine Simulator was created with an Arduino UNO and a Touchscreen LCD. Simulates Enigma I, M3, M4, the Plugboard and Uhr Switch.
arduino-enigmaArduino Enigma 08/11/2015 at 22:160 Comments
Development Day 56
-updated enigma logo to have two blank lines between letters
-texture is completely erased when opening machine
-created logo background bitmap which erases texture inside logo
-changing reflector shows only wheels applicable to that machine
-when reflector is changed, wheels not applicable to that machine are removed from mechanism (BD,G,8,7,6)-(A,blank)
-no serial printing
-no comments of BUG: type
to do:
-encode characters thru serial
-menu or no menu thru serial??? only settable physically
-display i,m3,m4 on corner?
very close to code complete...
-fixed bug when wheel 8 in leftmost position with B reflector does not get erased when changing to A reflector
-added machine name and year under enigma logo
-added storage of all 13 stecker pairs, uhr is only effective when 10 are used
-changed main gui display order, first wheels, then logo
-changed default printing groups to 5
-when EnigmaData is initialized for the first time, uses loop to store 0 in Pairs instead of strcpy, fixes garbage on stecker display
-changed some ints to bytes on main file
-added elliptical bezels to wheels
-changed DrawOpenContacts to clear wider bezels
todo:
-eliminate flicker on stecker printout
-serial encoding
-added serial port options to menu, 0 (no serial operation), V (verbose, educational mode, default), E (encode thru serial)
-modified detection areas and status printout for menus
-added serial variable to enigma data persistent variable
-added knob to close machine on top left corner of mechanism box, can also close through menu
-more realistic rotor bezels, added screws, darker background on letter.
-implemented GUI_UPDATE on DrawWheels
to do:
-implement serial functions
-fix flicker on stecker tape
-rotor rings move when being set or machine working in both open and closed views
-verbose mode implemented, wiring path, stecker and rotors are shown
-when in coding mode, letters sent through serial port are encoded, lower case is converted to upper, all others ignored
-changed baud rate to 9600
todo:
-add code version
-flicker on stecker tape eliminated
-fixed bug where DrawWheels would paint a gray square over letter, added check for GUI_UPDATE
-flat rotor has now 26 contacts
-added 1 more pin to open rotor contacts
todo:
-credits/about screen
-fixed bug where machine would encode thru serial outside of the main screen, resulting in screen corruption when open
-wheels can be set thru serial port with ! command, opening the machine mid sequence cancels it
RC1
-implemented about box, shows on boot for 4 times, then is only shown from open machine menu.
-added F() function to drawString
