It has begun!
A project log for Telegram Control
Telegram is a great IM client. Recently they implemented a bot API. Telegram control is a hardware device that can be controlled by Telegram
tom-van-den-bonTom Van den Bon • 06/29/2015 at 11:59•0 Comments
I decided to do this project after we successfully implemented a telegram bot on a raspberry pi running at our local hacker space (BinarySpace). I felt that a raspberry pi is a bit overkill and that this can probably run just as well on a embedded device. The only real caveat I currently see is getting ssl working on the embedded device.
There are a few options that I'm looking at and now that I have received my devboard I can start on the code :)
