Soldering (of the first one) ready
A project log for tiny7
small seven segment display for plugging on an ISP programming header of an Atmel Board or an Arduino
alexAlex 07/20/2015 at 20:042 Comments
So I did solder the first tiny7 PCB:
I think this looks quite good and it did also work at the first try!
As resistors for the segments I used 1kOhm this time. So ~3mA flows through each LED. With this current I am now in spec. of the HC595 and the display is bright enough.
davedarko wrote 07/20/2015 at 20:25 point
looks awesome!
Alex wrote 07/20/2015 at 20:37 point
Thanks!
