More Bords soldered
A project log for tiny7
small seven segment display for plugging on an ISP programming header of an Atmel Board or an Arduino
alexAlex 07/22/2015 at 14:430 Comments
More Boards:
The display is mounted different on each one. The library already supports the Display mounted on the other side. Next I will add support for displays mounted upside down. Therefore I do have test-hardware now.
