First detection tests, powered by AForge
A project log for Grigore - Robotics for everybody
Let everyone write and test code, on the same platform, by just having an intelligent line-following table.
strofostrofo 07/23/2015 at 08:260 Comments
I love the AForge framework from Andrew Kirillov so it made sense to use it because Microsoft just released the Raspberry Pi support in Visual Studio C#.
Right now I am still in doubt weather I will use Mono or .Net but is clear to me that I will use C# instead of Python. I can use some advices and feedback on this matter.
The code just makes a difference filter between an original empty board image:
and an image containing the robot (made using GIMP):
and returns an image containing the resulted edges:
Code can be found here:
https://github.com/strofos/grigore/tree/master/SOFTWARE - Board/Test01 - Detection using AForge
