SMD SOLDERING NEW AND IMPROVED
A project log for SMD Soldering Made Easy
A quick 'dirty' technique to solder fine pitch SMD components on a HASL PCB with only flux.
LazyHDLazyHD 03/06/2016 at 17:170 Comments
Unlike the other video which used solder flux alone, in this video we will be using a mixture of solder flux and solder paste. In the video below the mixture is formed of around 70% solder paste and 30% solder flux (I think this can be changed, and maybe solder paste alone might do the trick but adding the flux will surely make it an easier task). Anyways I am happy with the results, I have tested the PCB and the results were great without any modifications. Now 3 months have passed since I have soldered this PCB and it is still functioning normally without any problems.
More Photos
