First Software Envelope Generator
08/26/2015 at 21:13 • 0 commentsFirst tests with my controller board ATMEGA 32, 8Mhz LTC2756 18Bit DAC
Made some changes in the coding.MAXVALUE=262144
A_Rate = 1000
D_Rate = 500
S_Level= 131072
R_Rate = 250
Update Rate: 1ms
Oscilloscope Setting: 200ms/cmMAXVALUE=262144
A_Rate = 10000
D_Rate = 500
S_Level= 131072
R_Rate = 250
Update Rate: 1ms
Oscilloscope Setting: 50ms/cmMAXVALUE=262144
A_Rate = 100000
D_Rate = 500
S_Level= 131072
R_Rate = 250
Update Rate: 1ms
Oscilloscope Setting: 1ms/cm -
Start
07/03/2015 at 19:43 • 0 commentsI started my Polyphonic Synthesizer Project with an Arduino Board and an discrete build digital to analog converter.
First idea:
First breadboarding
