DIPSY meets Raspberry Pi
A project log for DIPSY
DIY System on Chip based on FPGA, priced below 5 USD
Antti LukatsAntti Lukats 09/05/2015 at 16:144 Comments
"Hey where is the Pi?" asks Andrei. After some in-depth search in the treasury box I can find an RPi model A. Here you go!
"Hey I need a DIPSY too! says Andrei an hour later - I take one from my desk, here you need some wires too!
Andrei connects the wires, and types the command to configure DIPSY:
This is the first time this RPi was ever used.
This is the first time DIPSY was used with RPi.
This is the first time Andrei has ever done anything with RPi.
There was no need to change anything in the code.
There was no need to change the wiring.
It just worked on the Pi.
Files on github
Andrei Errapart wrote 09/06/2015 at 16:31 point
Intel Edison and Beaglebone are in the club, too :) The same python script supports all the platforms.
Yann Guidon / YGDES wrote 09/05/2015 at 17:06 point
Andrei rocks !
Antti Lukats wrote 09/05/2015 at 17:30 point
Yes. It may look like peanuts when it is done, but taking unknown platform, and unknown device to talk to, then writing code, making fly wire connection. And getting first try full success? This rocks.
Yann Guidon / YGDES wrote 09/05/2015 at 17:34 point
This manipulation deserves a step-by-step howto :-)
